laknox
Sep 30, 2016Nomad
blkdodge wrote:nickthehunter wrote:coolmom42 wrote:X2
A properly installed PEX fitting will not leak. Emphasis on PROPERLY.
But it's a good idea to use a pressure regulator when water pressure is an unknown.
However, you have to do your part also which includes proper winterizing. 1 leak maybe, but 4 leaks and I begin to think "Operator Error". Not saying the fault is with the owner but seems highly irregular in my experience.
I don't think "OPERATOR ERROR" is a fair assessment.. I for have a 2012 Landmark also made by Heartland, and OP is correct in saying looks like a child plumbed it. The first morning I woke up to water all over the bathroom floor(bad connection at toilet). I have had countless leaks in my basement. Fix one and get two more leaks. I think I have them all fixed by now. This winter I plan on re-plumbing the entire water distribution panel with a manifold that has separate shut offs for hot and cold. Also I might add I'm a certified plumber.
I note that you and the OP both have '12 models. Could the same team have plumbed both? Be interesting to see your two build dates.
Lyle
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 10, 2026
