Linkbeltspeeder
Dec 21, 2013Explorer
Unless you are planning to do sightseeing on Long Island I would search for campgrounds in New Jersey or Westchester County in New York. Wildwood is a quite a distance from NYC for sight-seeing. If you plan on touring Long Island it's not a bad choice. To get to Wildwood your lesser of the evils is taking the George Washington bridge to the cross Bronx to the throggs neck bridge. All congested and bumpy. Take the clear view expressway to 495E out to,William Floyd parkway and then north to either 25 or 25 A not sure which to get to wildwood. FYI the William Floyd parkway should be the only parkway you should try to use. Trailers and RV's are a definite no no on Most NY parkways. Good luck and stay alert!
About Fifth Wheel Group
