6Gun wrote:
I have a new 31 ft. Rock-Wood and need to get the shaking under control when parked. My wife has a really bad temper when woke up in the early morning:S. There are so many products on the markets I'm not sure what works the best. I have a Side Winder king pin so I don't think a front tri-pod stabilizer will work. Maybe Wheel Locks?
I do have electric landing gear on the back it helps but its not great.
Thanks
All the stabilizers in the world won't stop all the movement, you are sitting on rubber tires ,and leaf springs . The stabilizers will prevent the fifth wheel from shifting back to front ,and side to side, but you will still get some up ,and down movement . If you want to stop all the movement you will need to get the weight of the leaf springs ,and tires . I have seen guys put jacks in front ,and rear of the tires both side just tight enough to take the bounce out of the tires ,and leaf springs. Personally the stabilizers work well enough for me ,but I don't have a mean wife :)
On edit : Steadyfast are very good stabilizers ,a little simpler in design ,and gets the job done very nicely
