goducks10
May 26, 2015Explorer
Cummins12V98 wrote:goducks10 wrote:
2013+ Any of them are fine.
Pre 2013 I would pass on the Ram. No DEF. Oil changes are too frequent for full timing. Plus prior to 2013 the Rams 3500 DRW has a lower payload and tow rating than Ford or GM. Ram really upped the ratings for 2013+ on the 3500.
Pre 2013 I'd go GM-Alison 1st, Ford 2nd.
I'm a Ram owner FWIW.
One thing i would disagree with you on is the "Oil changes are too frequent for full timing" statement. With my 11 RAM Dually I changed oil at or near the 7,500 mile mark most of the time. I full timed the whole time I owned the 11. Now with the 15 and full timing I suspect my changes will exceed 10K.
I've never made it past 4000 miles per the EVIC. In fact most are in the 29-3400 range. Are you deleted? From reading on the Cummins diesel forum some of the long haulers that aren't deleted can get 5000. I just don't see how you got 7500 on a non deleted 11 Cummins. I know the manual says 7500/6 months but it never happens.
About Fifth Wheel Group
