cummins2014
May 28, 2015Explorer
Cummins12V98 wrote:up2nogood wrote:Arcamper wrote:up2nogood wrote:Cummins12V98 wrote:WeBeFulltimers wrote:TucsonJim wrote:
Love our '13 Ford F350 with a 6.7 diesel. But please consider getting a dual rear wheel truck. A 38' FW will have a lot of pin weight, and if you get a diesel truck, your payload will probably not be sufficient with a single rear wheel truck.
My 38' Montana has a pin weight of 2440 verified by CAT scale. My SRW legally handles it just fine.
Not calling you a liar but did you have any personal belongings inside the 38' Montana? That's a very light pin!
I will back him up, my 38' foot Montana has a pin weight of 2420, partially loaded. Everything I haul in the basement was loaded ,only thing added up front was clothes, the fridge food, but thats far enough back that it is not getting the total weight on the pin . I too was surprised that the pin was that light. I am going to be fully load here in about two weeks for a trip, and I will weigh again, but I don't expect it to be over 2700. Hopefully that 2014 Ram will handle it.
I don't haul a bunch of junk like some I have seen . I have been towing fifth wheels for about 10 years, and pretty much got it figured out what I don't need. I like to be able to see inside my basement , and find what I do need, not like some I have seen.
My 2016 36ft Montanna has over 3k lbs on the pin with no water but it does have a washer and dryer in the front closet. My Ram will pull it all day dropped into 5th gear with the cruise on at 70 mph on any hill around here.(not the west where the hills are bigger)The only part that hurts is watching the fuel mileage drop to 4.
My Ram handles that Montana fifth wheel of mine with no issues. I have yet to pull any mountain pass here in Utah, Idaho, and Montana that I can't maintain the speed I want.
Actually I have never got worse then 8 , and 12 at the best towing.
Those weights blow me away! My Pin is twice that.
I agree, I will weigh again, not that it is a problem, but keep hearing all these heavy pin weights. You do have a fifth wheel that is probably half again heavier then mine.
About Fifth Wheel Group
