Taco
Dec 31, 2013Explorer
when you are done using the generator if you have the option of turning the fuel off to the carburetor and letting it run itself out of gas it doesn't leave any fuel in the carb to cause problems. Make sure you don't have anything running off the generator while you are running it out of fuel.
I sometimes use fuel treatments but as long as you run the float bowl empty you should not have major problems.
As far as a load I use a space heater. Exercising it has more to do with the generator head than keeping the carb clean.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
