SDcampowneroper
Mar 29, 2020Explorer
if you can find the same vinyl, tape a piece over rhe damaged area pattern matched , then cut thru both layers with a razor knife to make a patch. Remove the damaged area, glue down the patch. Flooring stores have products to blend in seams, make a parch disappear.
You shouldnt transport firewood, unless its kiln dried. Might move a disease
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
