Njmurvin's avatar
Njmurvin
Explorer II
Feb 07, 2017
Best way to switch from shore power to inverter?
I'm planning an upgrade to my solar capabilities which are quite minimal at the moment. Part of the plan is to use an inverter to power all the AC outlets when dry camping. I would probably be satisfied with a manual switch. But, 30 amp auto transfer boxes can be had pretty cheaply - so that's tempting. I just want to switch between shore and inverter power (disabling power to the converter/charger when in inverter mode). If I use a generator, I plan to use a portable and just treat it as shore power.
Is there a simple way to accomplish this?
  • Njm, what panels, controller and batteries are in the plan?
  • My Magnum transfer switch has made it three years so far, haven't had the bad luck Don has had.
    Inverter is wired whole house, and kicks in so fast there's not even a flicker if shore power goes out or I unplug the power cord.
  • Hi,
    I'm not a fan of transfer switches. I use male and female plugs. I want to know the power is OFF.
