Chuck___'s avatar
Chuck___
Best way to take care of the rubber roof? Recommendations?
Just got off the phone with the DRV factory and they really could not recommend any cleaner, protectors, sealers and or UV protection. Factory sad; just to wash it with mild soap. He said he did not know if the protectors, sealers and UV protectors/coating work on the rubber roof. I want take care for roof and outside of the 5th wheel and looking the recommendations.
PS: Contacted some DRV recommended service shops and they said that they use Dicor cleaner and UV protectors. Anyone had luck using these products?
  • “Factory sad; just to wash it with mild soap.”
    Why don’t you believe what the factory said? Keep asking and someone will say what you want to hear.
  • I'm with ksq5000: "remove debris and surface dirt/grime". I use Awesome cleaner and Murphy's Oil Soap, and a soft brush. I do go back over it with some kind of protectant when it's dry, the particular kind depends on what I have on hand.
