rerod
Jun 04, 2013Explorer
Dr Quick wrote:
Any wheel bearing grease will do, just DON'T use the zerk fittings to grease the bearings. Just look at other peoples expierence and see what problems it caused. You are much better off to pack by hand and forget the zerk fittings.
Thanks for pointing that out Dr.. I was wondering if I could save time each season with a zerk caps.
A don't know about everyone, or what the recommended service intervals are. I don't believe you need to be replacing bearings and seals all the time. Iv had good luck carefully removing everything except the seals. Check the brakes. Cleaning, Re-packing and good for another 5000 miles.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 22, 2026
