Miles_Away
Oct 15, 2014Explorer
rjsurfer wrote:
I just installed an EasyFlex equalizer and noticed I lost an inch or so of height, it was a tad lower in the rear before the install so this extra inch is a bit too much.
I can either raise the pin box or lower the hitch.
What do recommend?
What are their advantages and disadvantages of each method?
And of course what's the easiest?, I'm thinking lowering the hitch would be the easiest, let gravity help me out.
Thanks
Ron W.
I'm confused about your initial post. What you are saying is that the REAR of your trailer is now HIGHER than it was before the Easy Flex install, which means that the FRONT of your trailer would now be LOWER. If so, and based on your measurements, I would leave it alone, as it sounds like you have an almost perfect setup. If I'm reading your post wrong, then I apologize and you can again refer to all the other helpful posts.
About Fifth Wheel Group
