- CaptJeff1731ExplorerThe Open Range 399BHS comes with a option u shape lounge, no tub. Mine has the couch and table. No tub though but the half bath makes a difference ! As for handling the cold it has done well this cold snap I am not in it due to work so I drained everything put some pink stuff in and have a very small ceramic heater in the basement just for extra good measure plugged to a therma cube plug set to kick on at 32 degrees just in case to keep things warm around the water pump in the basement check out the OR 399 BHS it may be just what your looking for!
- peejaykayExplorer
sandyhillbill wrote:
Open Range 399BHS has everything you mentioned.
Oops--except bath tub.
How is the insulation on these models? R-38 "calculated" What does that mean? How does that compare with R-38 "legit"? - ependydadExplorerThe "bathtub" is the real challenge. Most seem to be coming with oversize showers. Mine, for instance is a really big shower than a tub (50x30 inches or something). It's huge, but only has a 6" lip for the door (which makes it really convenient for stepping in). But, when dear son (12 months then) needed a bath, we used a fold-up tub container for him.
I'm not sure many new big campers are coming with a tub... - sandyhillbillExplorerOpen Range 399BHS has everything you mentioned.
Oops--except bath tub. - Me_AgainExplorer IIITow Hauler! Lots of them will do it. Chris
- OpenRangePullenExplorerThe OpenRange RT331BHS is a TT with 2 slides one big bath, and a large u-dinette, and a BH.
Good luck. - OpenRangePullenExplorerIt would be at least a 3 slide and it would probably end up being a 5th wheel to accommodate the tub.
OpenRange RV might have something similar though.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
