steelpony5555
Jun 01, 2013Explorer
If you are looking at a used rig be sure to check the slide floors. They only had plywood that when it rains would run down and seep into the ends of the plywood. A lot of manufactors will cover the bottom with heavy plastic to prevent this. I think every one I looked at had soft corners on the slides.....Not sure if they changed on later models...
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
