jnharley
Jun 16, 2016Explorer
We just had this problem too (after seeing and responding to this thread). One of our rear levelers would not deploy and the reservoir contained pink fluid. We were able to fix it ourselves with a few parts-a funnel with a long tube and a manual pump used to remove oil from outboard motors. We called Quadra a couple of times for advice because we also needed to purge air from the hydraulic lines since we removed and drained them. It was a easy but messy repair and with the reusable pump and funnel plus the ATF fluid and shop supplies we spent about $75. We had to flush the reservoir about 4 times to get out all the contaminated fluid. It really is helpful if you have a person assisting you.
About Fifth Wheel Group
