ljr
Jun 16, 2016Nomad
jnharley wrote:
We just had this problem too (after seeing and responding to this thread). One of our rear levelers would not deploy and the reservoir contained pink fluid. We were able to fix it ourselves with a few parts-a funnel with a long tube and a manual pump used to remove oil from outboard motors. We called Quadra a couple of times for advice because we also needed to purge air from the hydraulic lines since we removed and drained them. It was a easy but messy repair and with the reusable pump and funnel plus the ATF fluid and shop supplies we spent about $75. We had to flush the reservoir about 4 times to get out all the contaminated fluid. It really is helpful if you have a person assisting you.
What I have done several times is to remove the reservoir entirely. That makes it much easier to clean out. There are 2 large Allen screws on the inside of the bracket that hold the pump in place. If you remove them it gives you enough play to get the reservoir out and expose the in and out screens. I've always found that the screens needed cleaned too. I do that with alcohol and let it air dry.
As you probably know, it's important not to overfill the reservoir or it will overflow when you raise the jack.
About Fifth Wheel Group
