rhagfo wrote:
Dave H M wrote:
IAMICHABOD wrote:
One of the things is the rocking and the damage it can do when the bike carrier is mounted in a RECEIVER .
You need a good anti rattle device so you don't get so much play in the receiver,thus magnifying the movement and doing more damage to the bike carrier.
I have tried almost every Anti Rattle device on the market, most have been no good or so complicated and cumbersome that they are useless. Including the Roadmaster type,totally useless.
Until I found the one at Hitch Rider.
Their Hitch Vice is the best and easiest one I have come across and it really works.
I have one of those to take all the slop out of the hitch for the rack. I messed around for quite some time before stumbling onto that device. It is the cat's meow.
If you buy a quality bike rack it will have a bolt rather than a pin to attach to the receiver. Our Swagman XC2 has a bolt that pulls the rack tight to the side of the receiver, with a pin to prevent it from backing out if you ignore it for years.
I do have a quality Swagman bike rack with the bolt,no matter how tight that you get it you will still have some slop,the Hitch Vice does eliminate all movement.
