Ready2gonow's avatar
Ready2gonow
Bike receiver hitch on a trail air king pin
I have seen pix of bike racks attached to king pins, but not on a trail air king pin. Has anyone had a receiver hitch welded to Trail-air king pin? I have a 2010 Mobile Suites, and don't like the ladder carrier for bikes. I have no receiver hitch on the rear, am considering adding one, but would rather carry two or 3 bikes up front on the king pin. In front of the one ton dually is also an option. What does everyone prefer? One other question, that might determine what I do...I would love to pull a swivel wheel trailer, like an Idaho tote, to carry a motorcycle. The extra wt. really concerns me. This of course would require a rear end receiver with 2 attach points. Anyone doing this with a 36' Suites? Again, I have asked 2 questions. Thanks for any advise and pix.
  • I don't have the Trail Aire I have a Moryde pin and I had a receiver tube welded on the box. It works great. However I am down to only 1 bike now. I am also interested in the Swivel wheel hookup for our Cameo.
  • Beaker wrote:
    I did not want to weld to it or drill holes in it. So I built the pin box hitch so that it mounts to the pin box bolts. It extends forward and sits just above the pin box, not touching it.
    I have a fifth airborne sidewinder. Any pictures of your mount?
    Don't know if it will work with the Sidewinder.
    Since I had some angle iron laying around, bought a receiver at Harbor Freight, and made it myself, it cost me about $25.
  • I did not want to weld to it or drill holes in it. So I built the pin box hitch so that it mounts to the pin box bolts. It extends forward and sits just above the pin box, not touching it.
  • BB_TX wrote:
    I made one for my 5th Airborne pin box. But it is not welded to the pin box. I did not want to weld to it or drill holes in it. So I built the pin box hitch so that it mounts to the pin box bolts. It extends forward and sits just above the pin box, not touching it. Easily carries 3 bikes and could probably carry a 4th but have not tried.
    Don't see any reason you could not do something similar to make one to fit the Trailair.
    After watching bikes bouncing on the back of trailers I did not want mine there. Very little movement up over the pin box.
    I have An Arvika pin box bike rack that attaches as described above. It bolts on using the existing pin box bolts.
    Contact Arvika. They maybe your solution
  • Can't really help you with the bicycle rack idea but reference the swivel wheel I do have some experience in that arena. We have a 2010 Mobile Suites 36tk3. We use the swivel wheel for our Harley. I would be happy to answer any questions you might have in regards to this arrangement. Also look forward to anyone's experience with a similar set-up.
  • I made one for my 5th Airborne pin box. But it is not welded to the pin box. I did not want to weld to it or drill holes in it. So I built the pin box hitch so that it mounts to the pin box bolts. It extends forward and sits just above the pin box, not touching it. Easily carries 3 bikes and could probably carry a 4th but have not tried.
