- B_O__PlentyExplorer IIWhy is it important to get rid of them? The more you scrub, the more of the wear layer you take off shortening the lifespan of the the roof. Mine gets washed when it rains. I just don't worry about it..
B.O. - jkbreaExplorerI noticed my fifth wheel roof also is covered with black spots, about the size of a dime. I used a soft brush and simple green solution about 3-4 times a year and once a year use a roof protectant that mops on.
I tried cleaning it today. It cleaned the roof but not the spots. I called Richardsons RV near where I live. They said it is a mold caused by mildew and it won't come off. He said scrubbing may fade it but wont't remove it. He also said it will not harm the roof and it is ok to use rubber conditioner or any other product I have been using.
Hope he's right.:@ - Me_AgainExplorer IIISpic-n-span power and a stiff long handled brush, and a lot of work. Chris
- cummins2014Explorer
Fresno Tundra Driver wrote:
BarneyS wrote:
I could be the white coating is wearing off exposing the black rubber.
Barney
X2. It's not mold it's just the white coating wearing off.
Thats funny, I too have the black spots all over the roof, but a little hard rubbing ,and they come off, does not look like a white coating rubbing off , the black spots disappear. - wvcampersExplorer
ilvtravln wrote:
YnotTurbo wrote:
These are mold spots. They do not harm the roof. Just not very attractive. My fiver has them too.
Might be mold spots will take a closer look, Thanks
Mold spots is why the bleach works, Just give it a try. - ilvtravlnExplorer II
Barney
According to Trailer Life white is suppose to flake off slowly, mine may be going too fast. - ilvtravlnExplorer II
Might be mold spots will take a closer look, Thanks - ilvtravlnExplorer II
Chopperbob wrote:
There are coatings available to refresh your roof.
Not costly and DIY. Rubber roofs slowly wear out.
Before it gets real bad coat it. I've done several.
Clean it primer then two coats of finish. I admit I'm in
Cal where it's sunny most of the time but it's doable.
I also used it on my awning and the roof of my shed.
I coated it but the spots came thru again, Thanks - waltbennettExplorerThe white coating on an EDPM rubber roof is an ablative one and is INTENDED to slowly come off. That's where all the streaks come from on the sides of our trailers. The actual roof membrane is black rubber, and it will show once the white is all gone. Even then, the roof is still good. Just doesn't look pretty and has more solar gain potential.
- Fresno_Tundra_DExplorer
mtofell1 wrote:
I had the same spots on the roof of the TT I just sold. I scrubbed at them with some various cleaners and they didn't budge so I left them alone. There's absolutely no surface deterioration so I don't agree that it's the roof "wearing away".
Keep in mind EPDM rubber is in use on 1000s of commercial buildings in the nation and there are zero maintenance requirements. Certainly, if it makes you feel better to make someone rich buy buying their "softener" products go for it but it's not necessary. Keep the physical debris (leaves, etc.) off of it to allow for the intended water flow and you're good.
The roof itself isn't "wearing away". Like you said, EPDM is made to last(20 year warranty). The white material is only the outer coating. Look in your gutter after you wash your RV next time.
About Fifth Wheel Group
19,042 PostsLatest Activity: Jun 03, 2022
