drillagent's avatar
drillagent
Black Tank Explosion
My parents have a 2003 Excel 5th wheel that they are living in while they rebuild their house that was destroyed during the Joplin tornado. The other day they heard what sounded like an explosion that shook the rig. Dad later found out that the black tank split across the top the full length of the tank. So now my question to you is, what would cause a blank tank to do that and is it repairable or does it need to be replaced? The trailer is basically set permanently because they don't have a truck to move it with. Any help would be appreciated. Thanks.
  • ">weld is working not pretty but wanted it strongIf the trailer is new enough to replace the tank that is the way to go. IF NOT THEN it can be plastic welded. I could not find a close replacement for my 2000 Sea Breeze so I took an old big soldier iron that my dad gave me and welded on a stainless plate and soldier up the 115 gallon tank that was split at the seam.
  • oldmattb wrote:
    Is the RV hooked to a septic system? Unless they plan to travel with it, they could bypass the tank entirely.
    Matt B
    Is that possible? If you bypass completely solids will get plugged up in hose to sewer.Unless im missing something you cant bypass the tank,you need the water of the tank to stop solids from turning to cement.
    My guess from your description it was a vent that was blocked and gases caused the "explosion" sound.If it froze I believe it wouldnt have sounded so much like an explosion.
    Personally I wouldnt want to repair a black tank if it split down the entire top.I would replace.
  • You're going to have to remove it in either case, so I would suggest replacing it.
  • Is the RV hooked to a septic system? Unless they plan to travel with it, they could bypass the tank entirely.
    Matt B
  • The only thing I can think of that would cause it, is a clogged roof vent. Gasses build up in a black tank and they have to go somewhere. Sounds like a weak seam. You may be able to do a temporary fix if you can get to the top of the tank but I'd replace it eventually. But first check for clogged venting.
  • Most tanks are polyethylene - they CAN be repaired by anyone who's able to do "plastic welding". But I almost wonder if it would be easier to replace the tank? And unless it was ice that split the tank - the vent also needs to be cleared...
