schlep1967
Sep 19, 2022Nomad
Gorilla tape is your friend.
You can cut a 3 sided flap, leaving the side towards the front of the trailer attached, and pull it down to get a good look up inside. Then once you are finished make sure the coroplast is clean (as in use soap and water to clean it) and dry. Then apply the gorilla tape. It is usually easier to clean it before you cut it then do minor cleanup before taping.
Also, Get the tank emptied and rinsed as much as possible before you try to work on it or take it to a shop to work on it.
Best scenario is you had it really full and that pressure squeezed something out through a not so sealed opening. I would limit the bathroom use to family or watch the tank gauge (if it works) and cut off the bathroom privileges at 3/4 full.
About Fifth Wheel Group
