PokerCamper
Sep 15, 2017Explorer
Keily wrote:
I don't know if this will help you or not, but it may help. I have helped an RV tech replace 2 black water tanks on 2 2012 Palamino 5th wheel trailers ,in the same campground, in the same season. What we discovered there was a hairline crack at the very top of the tank corner. It would only leak when the tank would get full and as long as the owner dumped every few days there was no problem.
Thanks, this is exactly what's happening with my tank but mine starts leaking as soon as it holds four or five flushes. The dripping just gets stronger the more full the tank gets, but as soon as I open the valve to dump, it slows down dramatically.
I'll try sanding the area down and applying the JB WaterWeld epoxy putty to see if that works.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 16, 2026
