Fisher_Bill's avatar
Fisher_Bill
black water holding tank valve opens but won't drain
Hey All,
The reason I posted this was so someone else might search this phrase and get a match, I did not (on this site) so after looking around I tried an idea that could get me off the hook.
We went tailgating last Saturday in Eugene, OR and it was dry camping only so I shocked the water system and rinsed into the tanks and went to the water treatment plant.
Hooked up and pulled the cable T handle that runs into the belly through the corrugated plastic, it came out the usual distance but no noise, I put it back in and pulled it out a couple of times but nothing.
So frustrated, I drained the grey tanks, fore and aft and told the guys to limit their bathroom use and so I stewed about it all weekend.
Searched several threads and the net and found an idea that made some sense, I was sure the cable was not broke so here's a recipe I followed.
Take one full bottle of Dawn dish washing soap and pour the whole thing down the toilet and let it sit there for several hours.
Prepare the rig for towing, take and dump 3-5 bags of ice (I did 28#'s) right down the toilet and then hit the road, I went over speed bumps and all of the hilly side streets where I knew the trailer would bounce around a lot and in about 25 minutes I headed for the dump station.
There was a MH and a TT already there and we chatted and I told them what had happened and what I had done and by the time it was my turn they stuck around and low and behold when I opened up the valve we all heard ice cubes come a tumbling down, if I wasn't under the rig it would have been high fives all around.
I know the moral of the story is to take better care of the tank but I thought this was genius, fill with soap and then ice cubes and use the cubes as a huge scrubbing agent to slosh out the tank and scrub the sides while driving and lubricating the slide valve in the process.
I hope this might help others cause it sure helped me.
Bill
  • Hi,
    Some one did a lovely test and published it on Youtube. The ice did just about nothing. Nor do the back flush devices work well. Sewer solution works a bit better, if there is a "straight shot" into the tank and if the water pressure is high. Rinse sprayers at the top of the tank do the best.
    https://www.youtube.com/watch?v=iH6acEmqvcw&t=20susing ice.
    https://www.youtube.com/watch?v=dfTd0Slt_cUComparing Tank Flushers in the Clear RV Black Tank
    https://www.youtube.com/watch?v=zYJCLzGaaB8Sewer solution test straight shot 120 psi
    Fisher Bill wrote:
    pianotuna wrote:
    The ice does just about nothing--it is the water and the detergent.
    When we deep sea fish for tuna we make an ice slurry in the bow compartment and when it starts to melt we can hear the ice cubes sloshing back and forth rubbing against all sides of the aluminum compartment so I have to believe that 30#'s of ice does something, YRMV
  • How about simply adding enough water to begin with so these "FIXES" simply don't need to be used!
  • The ice does just about nothing--it is the water and the detergent.
  • philh wrote:
    liquid water softener too
    Otherwise known as the GEO Method... :B
    Lyle
  • Moral of the story is to add PLENTY of water to the black tank after flushing.
  • Frequent dumping after intentionally filling the black tank works too.
