firemedic08ExplorerApr 27, 2017Black Water Waste Gate replacementI had the fun task of replacing the Black Water Waste gate this weekend. Here are some pictures. The reason for the replacement was because the Metal Bar pulled out of the blade. Cutting t...Show More
Hiking_HunterExplorerApr 27, 2017UUuuuh, did the rod pull out in the open position? If not, how did you empty the tank?
Related ContentWater pump?Water Heater Replacement RecommendationsWhy no hot water?black water tank replacementBlack Water Accident
