Me_Again
Dec 21, 2015Explorer III
omextreme wrote:
So I managed to hit the truck with the camper tonight on the passenger side and blow out the window and dent the cab but I am confused.
I am running a non slider hitch, The Anderson setup on a short bed. I know I really should have a slider but I went with the Anderson to save weight.
Here is the confusion... When i first tested the setup I was able to turn to the left on flat ground rolling forward to just shy of 90 deg...
I hit the cab tonight during a right turn moving forward not much past 75 deg on totally flat ground.
I never tested a hard right turn I just assumed that since a left turn didnt hit, the right wouldn't either...
What am i missing? Why did i hit on the right turn?Moderator edit to re-size pictures to forum recommended limit of 640px maximum width.
This was a fortuitous statement that you made earlier!
"I hope to see pullrite make a direct to puck auto slide hitch soon, give me reason to go to a standard hitch from the Anderson Ultimate i run currently (nothing wrong with anderson in my mind but my clearances are just a little too tight) "
About Fifth Wheel Group
19,031 PostsLatest Activity: Apr 14, 2024
