MFL
Dec 21, 2015Nomad II
Me Again wrote:
I a bit surprised that you hit just going forward. Many have said that the truck will not turn sharp enough for that to happen. I have a 2015 3500 SRW SB 4x4 RAM with a B&W manual slider. I bolted the uprights for the hitch head in the rear position and have only done three test tows so far of 100 miles each. End of the week we are off to Arizona and my plan is/was at the registration check in area to slide the hitch to the rear and at check out slide it forward. I will have to watch it at other times now!
Lots of people told me to get the B&W RVK3600 or Andersen and set it to the rear most position! I am glad I chose to at least get the manual slider.
Chris
Chris, OP was making a U type turn going forward in a parking lot. I think in most cases just turning at an intersection, most would not hit. With the FW always cutting to the inside, during a turn, it will cut sharper fast, in a continuing turn, such as the OPs situation.
Sorry for your damage OP!
Jerry
About Fifth Wheel Group
19,031 PostsLatest Activity: Apr 14, 2024
