omextreme
Dec 22, 2015Explorer
The Anderson has a couple of adjustments. One is how you orient the hitch itself (can be forward or aft of the gooseneck), and the other is how you orient that kingpin adapter. I believe in total you have about 8" of potential offset between the two of them.
Yes the anderson can be set further back, But sadly Like so many others I failed to research the Cargo Capacity side of things when I Bought the 2500. I was trying to keep the pin centered or slightly ahead of the rear axle since I am so close to max capacity...
About Fifth Wheel Group
19,031 PostsLatest Activity: Dec 27, 2025
