jerem0621
Dec 22, 2015Explorer II
IdaD wrote:omextreme wrote:
The Anderson has a couple of adjustments. One is how you orient the hitch itself (can be forward or aft of the gooseneck), and the other is how you orient that kingpin adapter. I believe in total you have about 8" of potential offset between the two of them.
Yes the anderson can be set further back, But sadly Like so many others I failed to research the Cargo Capacity side of things when I Bought the 2500. I was trying to keep the pin centered or slightly ahead of the rear axle since I am so close to max capacity...
The rear springs on your truck are literally the only thing different from a SRW 3500, and they can handle a 3000+ lb load without issue (the 6.4 version of your truck weighs about the same empty at the rear axle but has a payload rating of around 3300 lbs if I'm not mistaken.)
Anyway, in the future I'd pay more attention to your 6500 lb RAWR and flip that Anderson around to give yourself an extra margin of error. I'm glad you brought this up though as it might explain why this accident occurred.
I am pretty sure that the rear suspension configuration is totally different from a 2500 Ram to a 3500 Ram.
IIRC the 3500 Ram SRW has traditional leaf spring suspension and the 2500 has 4 link suspension with coils. So, its not exactly like the old F250 to f350 SRW where you just swap springs and blocks and viola a 3500 is born.
Thanks!
Jeremiah
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 26, 2026
