IdaD
Dec 24, 2015Explorer
laknox wrote:omextreme wrote:arnko37 wrote:
Shortly after getting a new 2013 GMC 2500 HD I blew out the rear window while backing up. The hitch is a slider. Ever since I tow with the hitch slid back. No problems. However I would not do this on a slippery road. Since some weight is taken off the front axle there is a risk that should you try to turn you may keep on going straight ahead. The light steering axle will have less traction when there is less weight on it.
Are slider hitches rated to tow full time when slid?
B&W, definitely NOT, according to them. Personally, I wouldn't trust the hitch to hold in an emergency stop and now you've given your FW about a 12-14" "head start" in ramming forward, should the latch break. You'll have =something= in the cab with you if that happens.
Lyle
Ditto. I don't think it's a good idea at all.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 23, 2026
