remoandiris's avatar
remoandiris
Blocks under Level-Up feet?
Those of you with a Level-Up or similar system, do you still put wood or plastic blocks under the feet?
  • I put 6 x 6 treated blocks under all 6 of my hydraulic feet. I bought a couple of 6 x 6 x 8's from Lowes and cut them into 3 peices each with my chain saw. Works well and supports a lot of weight.
  • For me, it depends on the site. For example, right now we have a couple of plastic blocks under the left side. There is a depressions on the left side and without the blocks, the auto system wanted to raise the right side wheels off the ground.(Go figure!) So I put the blocks under both left side rear jacks (one each). Now all wheels are down and we are level. I like to keep the wheels down on the ground for the added stability.
    If the site is fairly level with no depressions, I just let the auto system do its thing. Had good luck with that approach.
