We have a Palomino Puma 295KBH that has a fuse right off the battery that goes up into the camper. The 15 amp fuse keeps blowing when I plug it into the truck or into the house. I couldn't even get my...
That might be true about the leak. I tested the battery with volt meter and it was at 7 volts. I will look at the wire tonight and let you know what color it is. can't see the converter very well with out taking it apart. I will try that also.
