SabreCanuck wrote:
rjxj wrote:
If a lot of it is road hazard why aren't the vehicle tires flat more often? Vehicle leads rig.
Obviously Not the same quality of tire and specifications. I'm NOT disputing that an LT tire is a better tire than an ST tire. That wasn't my point. My point is that anyone (perhaps millions) can run ST tires perfectly fine if/when they run them PROPERLY. So, let's remove the "ROAD HAZARD" comment for two seconds. What about twisting, turning, overheating, excessive speed, etc.? It never comes up....
Nobody ever asks "FRED" (sorry Fred) how they drive or turn or park or outside temperature, speed, etc.... The immediate answer is "junk tires, go buy 4 new ones".
There are replies here in regards to tread separation, even on LT tires. The most common cause of Tread separation is due to excessive twisting which over-stretches the bond between tread and tire. May not blow out while you are twisting but the damage is there. when you add speed/heat to that tire it stretches to the breaking point and BOOM. Perhaps think about how/when/where you park and how those tires are twisting and change those habits.
Review your driving habits, or go spend a grand on better tires. The first option is rarely discussed or advised as it is always the "junk tires"...
Part of the problem with your theory is that when the tires that a person had problems with are replaced, there are rarely any more issues with exploding tires. If it were simply a matter of "twisting, turning, overheating, excessive speed, etc." then the issue would return and there would be more exploding tires. But that rarely happens.
If one set of tires simply cannot handle the stresses and loads which they supposedly are designed to do, that would suggest to me that they are indeed junk tires.
