JIMNLIN
Nov 13, 2018Explorer III
fj12ryder wrote:Carlisle came out with a improved RH ST tire in 2013. There has been reports like the OP's issue on the RH series tires.
Unlikely to get any satisfaction from Carlisle, but it sure doesn't hurt to try. That's a shame, as I thought Carlisle was getting their act together after making some sorry excuses for tires around 2010.
It sounds like you may have pulled a wire loose from the brake, maybe inside the drum/axle. A lot of the brake wires can be daisy-chained together, so if you lose one wire, you may lose another also.
Carlisle came out with the new and improved HD ST tires in sept of 2016 so the OP tires were the older Carlisle RH models.
Agree with others....check with Carlisle....and file a complaint on nhtsa tire complaints.
Be sure and give all info that is asked as NHTSA shitz cans those complaints that don't have the proper info.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 26, 2026
