mileshuff wrote:
I've been trying to decide if a Blue Ox is something I should install. I'm new to 5th wheels. I always chock the wheels and test pull with the front landing gears up about 1" from the ground. If my 5'er does drop its only going to drop that 1". Won't this work?
Your procedure will work for as long as you tow a fifth wheel as long as you continue to do the procedure you just explained, and you check to make sure you are not high hitched, which I have never understood how one can high hitch. I would have to guess they don't even bother to look ,which again does not make sense to me .
