lc0338
Sep 05, 2016Explorer
Since your truck is wired different... make sure your batteries are wired correctly. You did not mention if you have 2ea 12 volt or 2ea 6 volt batteries. If both batteries are same age and same maintenance and wired correctly you are better off getting 2ea new batteries because the other battery may be on it's last leg. Also not good to pair an old and new battery. It makes the new battery do all the work and usually lowers it's life.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 20, 2026
