Belly panel bolts are so small they snap off. Any quick fix? Do you have to drill in new larger self threaders or drill out holes and use new heavier self threaders.
Many will break when you try to unscrew them because they are really tight, and extremely brittle so the heads break off. You can't drill them out easily because they are so hard. I put the same size back in because the size is right.
