time2roll
Dec 28, 2016Nomad
I would have a second RV water pump. Make a custom adapter hose to pump from your container. Will also serve as a back-up pump if existing pump fails.
If you are already camped.... you may need to pull the trailer close to the water supply to fill. I have 300' of that flat hose to reach an extended distance to a spigot as needed. Has served well in Yosemite and Death Valley.
Good luck if you are stuck with just a funnel and a hose to pour water in.
About Fifth Wheel Group
