flyfishing48
Dec 29, 2016Explorer
If you put the winterizing hose into a jug of water it will be pumped into the water lines just like the antifreeeze would But I don't think it would go into the tank because of a check valve in the suction side of the pump or the because the valve that allows the pump to pull from the jug shuts off the line to the tank. Or am I not think this correctly?
But this set up will pump all of the water out of the jug or tank. So for 5 gals or so at a time it would work. Right?
About Fifth Wheel Group
