bandit86 wrote:
I need a small quiet generator, likely going to get a Honda 2000i inverter. How many amps is the air conditioner draw on these units? The rest of the lights might get changed to LED
Congrats on the RV.. I's almost identical to my KZ MXT20 Coyote.. did a double take when i looked at the post.. LOL
A/C is probably same as mine, I had a Honda 2000i and it was not happy
with this unit even with a hard start kit on the A/C.. so I went to a 3000 Watt genny and all's well now.. problem with all a/c units is the LRA ( locked rotor amps ).. you need almost 3x the running current available to start, when running your unit will draw about 10 to 12 amps or so.. also another thing is the tires.. I did the calcs on mine fully loaded and the original ST's don't have any reserve at all.. I replaced them with Maxxis UE168(n) bravo's rated well above the GVWR.
Happy camping..!@
