bandit86 wrote:
Found a nice used WD hitch, 750 pounds, going to look at it today.
These trailer tires, i measure 5x4.25 stud to stud. Do any car or truck wheels bolt up? I don't know the hub diameter. I'd like to get some 16 inch rims for better ground clearance
Mine are 5 on 4 1/2.. problem is the clearance above the wheel..
I thought 15's would work, but the clearance is too small and would
rub on the wheel arch over bumps at full load.. so i stayed with the 14's and fitted better spec LT truck tires.. ground clearance has never been an issue for me..
