KevSchofield's avatar
KevSchofield
Bought a 5th wheel.. now I need a truck
My wife and I have been thinking about upgrading to a 5th wheel and stopped by the local Campers Inn to see what they had for used units..
They had just taken in a 2007 Jayco Eagle 325BHS in trade..
Super nice inside and out.. Has the optional larger bunk beds in the back with a rear entry door..
and the optional 'seperate chairs' dinette.
So now this is at the dealer getting prepped for delivery:
Dimensions and Weights
Overall Height (ft/in) 13'
Trailer Length (ft/in) 35' 4"
Interior Height (ft/in) 6' 9"
Gross Vehicle Wt Rating (GVWR) 12500
Unloaded Curb Weight (lb) 9605
Max Cargo Carrying Capacity (lb) 2895
Hitch weight 1825
So now I'm looking for a used truck to tow it with..
Will a short bed work? Anyone have experience with this particular front cap design? I know some 5th wheels will work just fine with a 6.5 foot bed without some sort of a slide hitch..
2 trucks I'm looking at.. 2000 Ford F250 extended cab 2WD with the 7.3 diesel and a 2000 GMC 4x4 2500 extended cab with the vortech 6.0 gas motor..
Both a short beds, both have a factory tow package..
Thoughts on one vs. the other? or am I going to need a 1 ton and a long bed?
Thanks,
  • I have just prepped my low mileage 2003 F250 to haul a 12K/2K fifth wheel. You should be very careful when considering any used diesel pickup truck.
    I put custom Curt frame mounts with in bed rails, Air Ride rear suspension, TruCool tranny cooler, a 16K B&W Patriot fifth wheel hitch and a Curt wiring harness. I also am installing a set of gauges with boost, pyrometer and transmission temps to go along with a D-P Tuner F-5 chip with 60 hp tow mode and 80 hp econo mode. I'm up to $1200 in expenses already. I've still got to change the transmission filter and 20 quarts of ATF and flush the radiator while replacing the thermostat and its housing.
    Any used 3/4 ton diesel should be taken to an independent diesel shop and a complete scan done on the engine to make sure it's 100%. (Just a set of injectors can run you a small fortune.) They should carefully checkout the transmission, as 3/4 ton trannys ($3K) are not long life items. The suspension and brakes should be carefully checked out, as they need to be at 100% condition for a tow vehicle. Brakes can be especially important.
    I don't mean to scare you, but getting a tow vehicle in shape is not a cheap proposition. Scariest thing is the price of fuel injection parts and $110 per hour labor rates. I'm fortunate to have a great independent shop that's reasonably priced.
  • I would probably agree that the 7.3 would do the job, but I think that pin weight is suspect. I think it's going to be north of 2k once you're fully loaded, which means you're approaching 1 ton territory. Either would probably be ok, but the 1 ton will make for an easier tow and less stress.
  • Nice RV!
    2011 or newer F350 or 3500HD SRW. Long box so you don't need a slider hitch.
    The hitch weight will be closer to 2300 lbs. Your curb weight is closer to 10,000 lbs. Our advertized dry curb weight was 9,700 lbs. Actual weight out the factory was 10,014 lbs - no propane, no slide awnings, all tanks empty and 1 battery
    You need payload for fuel, passengers, hitch, truck options, trailer options and anything you put in the truck box.
    Similar trailer - my CAT scale weight (two passengers and full tank of fuel - black and gray tanks empty - water tank about 1/3 full)
    Steer Axle - 4900 lbs
    Drive Axle - 6060 lbs
    Trailer Axle - 9220 lbs
    Gross Weight - 20,180 lbs
    Truck GVWR - 11,600 lbs
    Trailer GVWR - 12,380 lbs
    My truck weight with me in it is about 8000 lbs
  • I'd go with the 7.3 and a slider. you'll have all the power you will need with the 7.3 and since your 5ver doesn't have the rounded front corners, the slider will help in tight spots.
  • I would go with the 7.3 diesel and I would recommend a slider hitch given the design of the front cap on that Jayco.
  • I am a firm believer that you can never have to much truck. I have never had a Ford but I did have a 2003 2500 Chevrolet with the 6.0 and I found it to be gutless and fuel hungry. The 7.3 Powerstroke is known to be a reliable workhorse so that would be my choice between those 2 trucks assuming it was well maintained and everything else being equal.
  • Full ton SRW
    That half ton 6.0 Vortec would be right at the max capacity of what I would ever want to use it for. It will be downshifting a lot. If you won't be making many trips per year you might be able to make it work.
    Better to go with a full ton with a bigger engine though IMO.
  • I recommend a 1 ton SRW. My fiver in signature below weighs 12280 loaded with a 2400 lb pin weight. I had a 3/4 truck and was exceeding the truck payload (gvwr) by 500 lbs when loaded up so I moved to a 1 ton and am now within all safe specs of the truck.
  • Whatever one you decide on I would get a sliding hitch.
