empty_nest
Jun 20, 2014Explorer
Brain Lapse!
I guess it was bound to happen. The minute you take your eye off the ball, you screw up. After 4 yrs. with the 5'r, the first time I ever failed to do the pull test, I dropped her on the box. Fortu...
partsman01 wrote:oh boy wrote:
I have a Hijacker 16K, It has a flat bar that slides across the front of the pin.. The handle releases and slams across the pin. When I get out to check, the hitch is locked if I can put the lock pin in. If not then I check.
In 11 years I have one rule..if I get interrupted during my walk around check I'll start over. Never failed me yet..
I too have the same model, am thinking though of painting the bar white so it is easier to see, or seeing if reflective tape would stick to it, make it even easier to see.
I have access to yellow and white, plus some small red stick on reflectors.
