otrfun
Dec 07, 2016Explorer II
Appreciate all the input from everybody. I'm in no big rush, so taking my time to research all my options.
Given a choice, I think it's a no-brainer to route the brake lines on the inside of the frame rail; however, for those of us with a sealed underbelly it's a more difficult option. I would think running the brake line on the outside of the frame rail is not a major concern, as long as the brake line is routed towards the center axle area, prior to getting close to the wheel well/tire area. As I mentioned in my opening post, most of the installation pics and videos I've seen route the flex brake lines parallel with the sidewall of the tire. I would think dropping the primary brake line to the center of the axle a with flex line, then using a splitter to run brake lines along the axle housing all the way to the caliper assembly is a better option. That keeps the lines away from the outward trajectory area in the event of a blow out. I guess one's choice boils down to the odds of general road debri damaging a line if it's routed towards the center of the axle vs. a chance a tire blow-out will damage a flex line run next to the tire sidewall.
As for the discussion about steel vs. copper/nickel lines, yes, no doubt steel itself is "stronger" than copper and nickel. However, strength is not always the major concern for every application. I found this article a couple days ago (same article that JoeWay referenced) about the use of copper/nickel brake lines a very interesting read.
Here's a quote from this link that I found very interesting:
"Users of copper-nickel brake tubing in addition to Volvo include world-class vehicle manufacturers like Rolls Royce, Lotus, Aston Martin, Porsche and, most recently, Audi. Copper-nickel is also used in military, fire fighting and other heavy vehicles."
About Fifth Wheel Group
