klr650goldwing's avatar
Feb 06, 2019
Brakes are NOT working
We are at an RV park in Terlingua, TX. The brakes on the 5er are not working. I have the Curt 7-way RV blade style plug tester. It says the BK (electric brakes) terminal has no power. I checked all the fuses, they look good. The wiring seems normal. Can you give me any ideas what to check next? Is there a RV repair person in these parts? I googled and found one guy, who doesn't answer his phone. Thanks.
  • Do the other lights work on the rv, tail turn signal, etc. ? If they don't check for a loose ground on both the truck and rv side.
  • I checked all fuses with a voltmeter and key on. All fuses had voltage on both sides of the fuse. The controller light is on.
  • Is the controller indicator light on? Maybe a connection is loose. Did you check the brake fuse with a VOM?
