drwwicks's avatar
drwwicks
Brakes, break-away
Working on the new to us Prime Time Crusader 355. The break away isn't working. I just finished the chassis servicing, replaced bearing, adjusted brakes, and lube chassis. Brakes work when using the in truck actuator but when you pull the break away pin, brakes do not actuate. Do most 5th wheels have a separate small battery as part of the break away system? If so, where is it? Nothing in pin box but haven't checked in battery compartment. I did replace the house battery too.
To trouble shoot, I stuck pins in the wires, 2 black wires, coming from the break away switch and checked with a test light. Wires are hot whether the break away pin is in or out.
When I picked it up, the steel cable was broken so I couldn't clip it to anything anyway. But I want all systems working as they should.
__________________
