JRscooby wrote:
schlep1967 wrote:
Come on people. READ THE ORIGINAL POST.
His brakes wore out prematurely. That doesn't happen if his brakes don't work.
It happens when they are engaged and shouldn't be.
Most likely case would be driving with a foot resting on the brake.
After that I would look toward a short on the tow vehicle providing voltage to the brake circuit. Test at the trucks seven pin plug.
If it was the emergency breakaway the battery on the camper would be dead unless it is plugged in any time it is not hooked to the truck.
I read the OP. All my posts have been critical of what he has been told about the hunt for the problem. And you are right, the probability of the problem coming from Break-away-switch is 0.
And the chance there is a issue with driving style might be pretty good, but that is not the only problem.
3 out of 4 brakes wore out. Fact is 25% of brakes not working will cause rapid wear to the ones that work.
And once he has looked at the shoes, he knows which wheel has the problem. And if somebody that knows what the are doing replaced them, about the only place the problem can be is electrical, and in the branch going to that wheel, or ground.
The problem is we don't have all the details. He had power at 3 brakes with the breakaway pin in. So does he have a problem at one wheel or three wheels? Did he have the truck umbilical hooked up at the time of the magnet test? Where is the voltage coming from? the onboard battery or the 7 pin plug?
I agree that the one brake that was not worn out is not acting as the others, has a problem. But ... if no brakes are being applied none of the brakes should have power. It is likely there is more than one issue going on here.
