Timay wrote:
DHCamper wrote:
Everyone should check how their trailer is wired. Everything in my Rockwood is wired after the switch. Towing with the switch off means that the break away safety function will not work if activated.
Might as well throw the break away switch in the trash, then. If no safety stopping, no use for the switch.
Years ago we pulled a trailer house (a trailer house, not an RV) and since it didn't have a battery and items needed for RVing (think The Long, Long Trailer - we predated that movie) it didn't have a safety break away switch, my father drilled a hole in the handle of a regular light switch, tied a string through it, hooked it to the brakes and a dry cell battery and that was our safety break away switch - and shows my dad's commitment to safety.
And yes, I get that you 'turn it on' when traveling...but still - human memory being what it is...
Tim
Tell that to the manufacturers that wire them that way. I changed out the OEM toggle battery switch for a rotary switch. It's mounted exposed to loose items in the forward compartment. The engineer that came up with that must not be aware of what the compartments are used for. What's a person called that finished at the bottom of their engineering class? ENGINEER!
