CobraGT40's avatar
CobraGT40
Break-Away Trailer Brake Wiring... ?
Hey all
I wasn't really too sure where to post this, but it seems like a simple enough problem that someone might be able to offer up some advice ?
I am trying to replace my trailer brake break-away on my '98 Jayco Eagle 293-RKS and I'm a bit confused on how to wire this thing up.
The old one only has two wires (light blue and black with a yellow stripe...possibly yellow with a black stripe ?)
The new one has three wires (blue, black, white)
Anyone have a quick solution to this wiring conundrum ?
Thanks !
Scott
  • enblethen wrote:
    What is make and model of the new break away switch?
    Strange to have ground. Normally only two wire.
    The new break-away is
    Hopkins Towing Solutions #20050
    The old break-away is ESCO
  • What is make and model of the new break away switch?
  • Why would a ground connection be needed on a break-away switch? You're certainly not going to connect either your battery +12 line or your brake line to it.
  • Black.....power from battery
    Blue......to trailer brakes
    White.....ground
