mbrule's avatar
mbrule
Bridgestone Duravis R250
Could I ask a favor of one of you guys running Bridgestone Duravis R250s in LT285R16E? Could you post the max weight rating and max inflation? It does not seem to be available on Bridgstone's site. They are on my shortlist of possible replacement tires.
Open to other tire recommendations as well. I know this is discussed a lot around here and have read a zillion threads, but always open for more recommendations or experiences!
Thanks in Advance!!!
  • Paul Clancy wrote:
    Remember to subtract loaded pin weight when calculating.
    Have not weighed yet, but I am going to.
    Based on the specs:
    11050 Dry
    14000 GVW
    2181 Pin
    If I assume that I am at 14000 lbs (I do travel heavy), and pin weight is at spec:
    I would have 2181 on the pin and 11819 on the 2 axles, assume even distribution and that is 2955 on each tire leaving 87 lbs margin / tire.
    This just seems too close for comfort. I know there are a number of assumptions that I can clear up by actually weighing. Maybe I am just paranoid.....
  • roman traveler wrote:
    That's what I'm running, but I don't know the exact ratings. Go to Tire Rack.com and they will have all the information you need.
    RT
    Thanks, you were right!
    Now another question, most of the 235/85R16E tires seem to have a 3042 max rating. That is 42 lbs per tire safety margin (assuming that I am loaded heavy). I do not think that is enough (am I nuts or ?) and would like to go to a higher load range. I don't seem to be able to find a tire that will fit a 16 x 6 rim with a higher capacity. Do I need to go to 16 x 6.5 (only seem to be available in alloy $$$$), or even 17.5 inch wheels.
    I am so confused...... Any help or opinions appreciated.
  • That's what I'm running, but I don't know the exact ratings. Go to Tire Rack.com and they will have all the information you need.
    RT
