Johno02 wrote:
I installed one of these seeral years ago. Very bright, easy replacement, works very well.
Star Lights motion sensor porch light
I also have this light and like it a lot.
However, if the OP just wants a brighter bulb there is a variety of LED's available from many sources cheaper then C.W. The usual turn signal bulb is a #1141 or a brighter #1156. To match the 1156 brightness I suggest a bulb with at least 27 LEDs minimum in a bright white, not warm white. There are bulbs with 50 LEDs that should be really bright without the fear of melting the lender as LEDs are much cooler in operation. Check out eBay or Amazon.
