rjsurfer
Jun 02, 2016Explorer
Cougarnewbie,
A quick question, did you see the framing under the cap and how it was designed?
The results from doing the measurment test that Lippert said to make showed the pinbox was not moving at all, zero movement so I'm now at a loss as to why the bottom woodwork in both front closets are cracking and bowing a bit.
The problem area is very close to the front of the cap and maybe an inch or two from the bottom panel. This is way forward of the pinbox assembly.
Any ideas?
Ron
Any ideas?
Ron
About Fifth Wheel Group
